Size: 5.5 x 24
Design Span (L): 23.75 ft.
Clear Span: 23.50 ft.
Total Span: 24.00 ft.
Live Load: 320 plf
Dead Load: 320 plf
Selfweight: 735.0 lbs
Dist. Selfweight: 30.95 plf
Total Weight: 742.7 lbs
CV Volume Factor 0.915b - - - - -
Beam Design 2022A788
12/26/2022 1
d = 24.000 in.
A = 5.500 x 24.000 = 132.00 in.2
Sx = (5.500)(24.000)2/6 = 528.00 in.3
Sy = (5.500)2(24.000)/6 = 121.00 in.3
Ix = (5.500)(24.000)3/12 = 6336.00 in.4
Iy = (5.500)3(24.000)/12 = 332.75 in.4
12/26/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [132.00 x (285.00 + 3)] x (12 in./ft.)3 = 22.00 ft3
Volumespan = N[A x L] = 1 x [132.00 x 285.00] x (12 in./ft.)3 = 21.77 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 22.00 = 742.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 21.77 = 735.0 lbs
Distributed Self Weight (ws) = = 30.95 plf
320 plf
320 plf
  ws = 30.95 plf
23.75 ft.
23.50 ft.
24.00 ft.
8051.37 lbs
8051.37 lbs
12/26/2022 3
CV = = 0.915
CV = 0.915 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.915) = 2196.3 psi
fb = = 1075.2 psi
 fb = 1075.2 psi < Fbx' = 2196.3 psi  (CSI = 0.49)   ➜  OK
12/26/2022 4
fv* = = 75.29 psi
 fv* = 75.29 psi < Fvx' = 265.00 psi  (CSI = 0.28)   ➜  OK
fv = = 90.54 psi
 fv = 90.54 psi < Fvx' = 265.00 psi  (CSI = 0.34)   ➜  OK
12/26/2022 5
ΔLL = = 0.20 in.
(L/d)LL = 285.00 / 0.20 = 1419
 ΔLL = 0.20 in = L/1419 < L/360   ➜  OK
ΔTL = = 0.42 in.
(L/d)TL = 285.00 / 0.42 = 677
 ΔTL = 0.42 in = L/677 < L/240   ➜  OK
fc⊥ = = 488.0 psi
 fc⊥ = 488.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.75)   ➜  OK
12/26/2022 6
