Grade: DF SS
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 400 lbs
Dead Load: 50 lbs
Selfweight: 80.8 lbs
Dist. Selfweight: 5.88 plf
Total Weight: 82.3 lbs
Beam Design 2022A78
2/11/2022 1
Beam Design 2022A78
2/11/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [8.25 x (165.00 + 3)] x (12 in./ft.)3 = 2.41 ft3
Volumespan = N[A x L] = 3 x [8.25 x 165.00] x (12 in./ft.)3 = 2.36 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.41 = 82.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.36 = 80.8 lbs
Distributed Self Weight (ws) = = 5.88 plf
400 lbs
50 lbs
ws = 5.88 plf
13.75 ft.
13.50 ft.
266.15 lbs
266.15 lbs
Beam Design 2022A78
2/11/2022 3
Fbx' = (1500)(1.00)(1)(1)(1)(1.3)(1)(1) = 1950.0 psi
fb = = 891.7 psi
 fb = 891.7 psi < Fbx' = 1950.0 psi  (CSI = 0.46)   ➜  OK
Beam Design 2022A78
2/11/2022 4
fv* = = 15.92 psi
 fv* = 15.92 psi < Fvx' = 180.00 psi  (CSI = 0.09)   ➜  OK
fv = = 16.09 psi
 fv = 16.09 psi < Fvx' = 180.00 psi  (CSI = 0.09)   ➜  OK
Beam Design 2022A78
2/11/2022 5
ΔLL =   =   = 0.32 in.
(L/d)LL = 165.00 / 0.32 = 522
 ΔLL = 0.32 in = L/522 < L/360   ➜  OK
ΔTL =   =   = 0.40 in.
(L/d)TL = 165.00 / 0.40 = 418
 ΔTL = 0.40 in = L/418 < L/240   ➜  OK
fc⊥ = = 19.7 psi
 fc⊥ = 19.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.03)   ➜  OK
Beam Design 2022A78
2/11/2022 6
