Grade: 24F-V8 1.8E SP/SP
Size: 5.5 x 11
Design Span (L): 4.75 ft.
Clear Span: 4.50 ft.
Total Span: 5.00 ft.
Live Load: 12000 lbs
Dead Load: 6000 lbs
Selfweight: 73.6 lbs
Dist. Selfweight: 15.50 plf
Total Weight: 77.5 lbs
Beam Design 2022A774
12/14/2022 1
d = 11.000 in.
A = 5.500 x 11.000 = 60.50 in.2
Sx = (5.500)(11.000)2/6 = 110.92 in.3
Sy = (5.500)2(11.000)/6 = 55.46 in.3
Ix = (5.500)(11.000)3/12 = 610.04 in.4
Iy = (5.500)3(11.000)/12 = 152.51 in.4
12/14/2022 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [60.50 x (57.00 + 3)] x (12 in./ft.)3 = 2.10 ft3
Volumespan = N[A x L] = 1 x [60.50 x 57.00] x (12 in./ft.)3 = 2.00 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 2.10 = 77.5 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 2.00 = 73.6 lbs
Distributed Self Weight (ws) = = 15.50 plf
12000 lbs
6000 lbs
  ws = 15.50 plf
4.75 ft.
4.50 ft.
5.00 ft.
9038.75 lbs
9038.75 lbs
12/14/2022 3
fb = = 2317.3 psi
 fb = 2317.3 psi < Fbx' = 2760.0 psi  (CSI = 0.84)   ➜  OK
12/14/2022 4
fv* = = 223.70 psi
 fv* = 223.70 psi < Fvx' = 345.00 psi  (CSI = 0.65)   ➜  OK
fv = = 224.05 psi
 fv = 224.05 psi < Fvx' = 345.00 psi  (CSI = 0.65)   ➜  OK
12/14/2022 5
ΔLL =   =   = 0.04 in.
(L/d)LL = 57.00 / 0.04 = 1352
 ΔLL = 0.04 in = L/1352 < L/360   ➜  OK
ΔTL =   =   = 0.06 in.
(L/d)TL = 57.00 / 0.06 = 899
 ΔTL = 0.06 in = L/899 < L/240   ➜  OK
fc⊥ = = 547.8 psi
 fc⊥ = 547.8 psi < Fc⊥x' = 740.00 psi  (CSI = 0.74)   ➜  OK
12/14/2022 6
