Grade: DF No.1
Design Span (L): 10.75 ft.
Clear Span: 10.50 ft.
Total Span: 11.00 ft.
Live Load: 1000 lbs
Dead Load: 660 lbs
Selfweight: 129.3 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 132.3 lbs
Beam Design 2022A773
12/12/2022 1
12/12/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (129.00 + 3)] x (12 in./ft.)3 = 3.87 ft3
Volumespan = N[A x L] = 3 x [16.88 x 129.00] x (12 in./ft.)3 = 3.78 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.87 = 132.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.78 = 129.3 lbs
1000 lbs
660 lbs
ws = 12.02 plf
10.75 ft.
10.50 ft.
11.00 ft.
896.14 lbs
896.14 lbs
12/12/2022 3
fb = = 585.9 psi
 fb = 585.9 psi < Fbx' = 1000.0 psi  (CSI = 0.59)   ➜  OK
12/12/2022 4
fv* = = 26.17 psi
 fv* = 26.17 psi < Fvx' = 180.00 psi  (CSI = 0.15)   ➜  OK
fv = = 26.51 psi
 fv = 26.51 psi < Fvx' = 180.00 psi  (CSI = 0.15)   ➜  OK
12/12/2022 5
ΔLL =   =   = 0.05 in.
(L/d)LL = 129.00 / 0.05 = 2618
 ΔLL = 0.05 in = L/2618 < L/360   ➜  OK
ΔTL =   =   = 0.09 in.
(L/d)TL = 129.00 / 0.09 = 1504
 ΔTL = 0.09 in = L/1504 < L/240   ➜  OK
fc⊥ = = 66.4 psi
 fc⊥ = 66.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.11)   ➜  OK
12/12/2022 6
