Size: 5.5 x 18
Design Span (L): 29.54 ft.
Clear Span: 29.08 ft.
Total Span: 30.00 ft.
Bearing (lb): 5.5 in.
Live Load: 320 plf
Dead Load: 240 plf
Selfweight: 685.7 lbs
Dist. Selfweight: 23.21 plf
Total Weight: 696.3 lbs
Load Duration: 1.25
CV Volume Factor 0.922b - - - - -
Beam Design 2022A772
12/12/2022 1
d = 18.000 in.
12/12/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [99.00 x (354.50 + 5.5)] x (12 in./ft.)3 = 20.63 ft3
Volumespan = N[A x L] = 1 x [99.00 x 354.50] x (12 in./ft.)3 = 20.31 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 20.63 = 696.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 20.31 = 685.7 lbs
320 plf
240 plf
  ws = 23.21 plf
29.54 ft.
29.08 ft.
30.00 ft.
8748.26 lbs
8748.26 lbs
12/12/2022 3
CV = = 0.922
CV = 0.922 < CL = 1
Fbx' = (2400)(1.25)(1)(1)(0.922) = 2764.5 psi
fb = = 2570.6 psi
 fb = 2570.6 psi < Fbx' = 2764.5 psi  (CSI = 0.93)   ➜  OK
12/12/2022 4
fv* = = 117.27 psi
 fv* = 117.27 psi < Fvx' = 331.25 psi  (CSI = 0.35)   ➜  OK
fv = = 130.52 psi
 fv = 130.52 psi < Fvx' = 331.25 psi  (CSI = 0.39)   ➜  OK
12/12/2022 5
ΔLL = = 1.14 in.
(L/d)LL = 354.50 / 1.14 = 311
 ΔLL = 1.14 in = L/311 < L/180   ➜  OK
ΔTL = = 2.08 in.
(L/d)TL = 354.50 / 2.08 = 171
 ΔTL = 2.08 in = L/171 < L/120   ➜  OK
fc⊥ = = 289.2 psi
 fc⊥ = 289.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.44)   ➜  OK
12/12/2022 6
