Size: 3.125 x 6
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 475 lbs
Dead Load: 75 lbs
Selfweight: 60.4 lbs
Dist. Selfweight: 4.40 plf
Total Weight: 61.5 lbs
Beam Design 2022A77
2/11/2022 1
b = 3.125 in.
d = 6.000 in.
A = 3.125 x 6.000 = 18.75 in.2
Sx = (3.125)(6.000)2/6 = 18.75 in.3
Sy = (3.125)2(6.000)/6 = 9.77 in.3
Ix = (3.125)(6.000)3/12 = 56.25 in.4
Iy = (3.125)3(6.000)/12 = 15.26 in.4
Beam Design 2022A77
2/11/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [18.75 x (165.00 + 3)] x (12 in./ft.)3 = 1.82 ft3
Volumespan = N[A x L] = 1 x [18.75 x 165.00] x (12 in./ft.)3 = 1.79 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1.82 = 61.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1.79 = 60.4 lbs
Distributed Self Weight (ws) = = 4.40 plf
475 lbs
75 lbs
  ws = 4.40 plf
13.75 ft.
13.50 ft.
305.77 lbs
305.77 lbs
Beam Design 2022A77
2/11/2022 3
fb = = 1276.5 psi
 fb = 1276.5 psi < Fbx' = 2400.0 psi  (CSI = 0.53)   ➜  OK
Beam Design 2022A77
2/11/2022 4
fv* = = 24.24 psi
 fv* = 24.24 psi < Fvx' = 265.00 psi  (CSI = 0.09)   ➜  OK
fv = = 24.42 psi
 fv = 24.42 psi < Fvx' = 265.00 psi  (CSI = 0.09)   ➜  OK
Beam Design 2022A77
2/11/2022 5
ΔLL =   =   = 0.44 in.
(L/d)LL = 165.00 / 0.44 = 376
 ΔLL = 0.44 in = L/376 < L/360   ➜  OK
ΔTL =   =   = 0.54 in.
(L/d)TL = 165.00 / 0.54 = 304
 ΔTL = 0.54 in = L/304 < L/240   ➜  OK
fc⊥ = = 32.6 psi
 fc⊥ = 32.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.05)   ➜  OK
Beam Design 2022A77
2/11/2022 6
