Beam Design - Building Column for Wind
Grade: DF SS
Size: 4 x 8
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 320 plf
Selfweight: 58.8 lbs
Dist. Selfweight: 6.03 plf
Total Weight: 60.3 lbs
Beam Design 2022A768
12/8/2022 1
12/8/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (117.00 + 3)] x (12 in./ft.)3 = 1.76 ft3
Volumespan = N[A x L] = 1 x [25.38 x 117.00] x (12 in./ft.)3 = 1.72 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.76 = 60.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.72 = 58.8 lbs
320 plf
ws = 6.03 plf
9.75 ft.
9.50 ft.
10.00 ft.
2005.14 lbs
2005.14 lbs
12/8/2022 3
Fbx' = (1500)(1.15)(1)(1)(1)(1.3)(1)(1) = 2242.5 psi
fb = = 1865.0 psi
 fb = 1865.0 psi < Fbx' = 2242.5 psi  (CSI = 0.83)   ➜  OK
12/8/2022 4
fv* = = 101.24 psi
 fv* = 101.24 psi < Fvx' = 207.00 psi  (CSI = 0.49)   ➜  OK
fv = = 115.57 psi
 fv = 115.57 psi < Fvx' = 207.00 psi  (CSI = 0.56)   ➜  OK
12/8/2022 5
ΔLL = = 0.31 in.
(L/d)LL = 117.00 / 0.31 = 380
 ΔLL = 0.31 in = L/380 < L/360   ➜  OK
ΔTL = = 0.39 in.
(L/d)TL = 117.00 / 0.39 = 303
 ΔTL = 0.39 in = L/303 < L/240   ➜  OK
fc⊥ = = 191.0 psi
 fc⊥ = 191.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.31)   ➜  OK
12/8/2022 6
