Beam Design - Gable End Frame
Size: 10.75 x 19.5
Design Span (L): 39.00 ft.
Clear Span: 38.00 ft.
Total Span: 40.00 ft.
Bearing (lb): 12 in.
Live Load: 320 plf
Selfweight: 1916.7 lbs
Dist. Selfweight: 49.15 plf
Total Weight: 1965.9 lbs
CV Volume Factor 0.831b - - - - -
Beam Design 2022A766
12/8/2022 1
b = 10.750 in.
d = 19.500 in.
A = 10.750 x 19.500 = 209.63 in.2
Sx = (10.750)(19.500)2/6 = 681.28 in.3
Sy = (10.750)2(19.500)/6 = 375.58 in.3
Ix = (10.750)(19.500)3/12 = 6642.49 in.4
Iy = (10.750)3(19.500)/12 = 2018.73 in.4
12/8/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [209.63 x (468.00 + 12)] x (12 in./ft.)3 = 58.23 ft3
Volumespan = N[A x L] = 1 x [209.63 x 468.00] x (12 in./ft.)3 = 56.77 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 58.23 = 1965.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 56.77 = 1916.7 lbs
Distributed Self Weight (ws) = = 49.15 plf
320 plf
  ws = 49.15 plf
39.00 ft.
38.00 ft.
40.00 ft.
8882.94 lbs
8882.94 lbs
12/8/2022 3
CV = = 0.831
CV = 0.831 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.831) = 2294.9 psi
fb = = 1487.4 psi
 fb = 1487.4 psi < Fbx' = 2294.9 psi  (CSI = 0.65)   ➜  OK
12/8/2022 4
fv* = = 56.81 psi
 fv* = 56.81 psi < Fvx' = 304.75 psi  (CSI = 0.19)   ➜  OK
fv = = 61.97 psi
 fv = 61.97 psi < Fvx' = 304.75 psi  (CSI = 0.20)   ➜  OK
12/8/2022 5
ΔLL = = 1.39 in.
(L/d)LL = 468.00 / 1.39 = 336
 ΔLL = 1.39 in = L/336 > L/360   ➜  NG
ΔTL = = 1.93 in.
(L/d)TL = 468.00 / 1.93 = 242
 ΔTL = 1.93 in = L/242 < L/240   ➜  OK
Ab = b x lb = 10.75 x 12 = 129.00 in2
fc⊥ = = 68.9 psi
 fc⊥ = 68.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.11)   ➜  OK
12/8/2022 6
