Beam Design - Gable Beam Fabric Ld
Design Span (L): 11.00 ft.
Clear Span: 10.00 ft.
Bearing (lb): 12 in.
Live Load: 300 plf
Selfweight: 132.3 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 144.3 lbs
Beam Design 2022A765
12/8/2022 1
12/8/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (132.00 + 12)] x (12 in./ft.)3 = 4.22 ft3
Volumespan = N[A x L] = 3 x [16.88 x 132.00] x (12 in./ft.)3 = 3.87 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.22 = 144.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.87 = 132.3 lbs
300 plf
ws = 12.02 plf
11.00 ft.
10.00 ft.
2322.15 lbs
2322.15 lbs
12/8/2022 3
fb = = 740.0 psi
 fb = 740.0 psi < Fbx' = 1035.0 psi  (CSI = 0.72)   ➜  OK
12/8/2022 4
fv* = = 52.32 psi
 fv* = 52.32 psi < Fvx' = 207.00 psi  (CSI = 0.25)   ➜  OK
fv = = 63.07 psi
 fv = 63.07 psi < Fvx' = 207.00 psi  (CSI = 0.30)   ➜  OK
12/8/2022 5
ΔLL = = 0.12 in.
(L/d)LL = 132.00 / 0.12 = 1141
 ΔLL = 0.12 in = L/1141 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 132.00 / 0.15 = 884
 ΔTL = 0.15 in = L/884 < L/240   ➜  OK
Ab = b x lb = 1.5 x 12 = 18.00 in2
fc⊥ = = 43.0 psi
 fc⊥ = 43.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.07)   ➜  OK
12/8/2022 6
