Beam Design - Restoration Barn Modified
Size: 12.25 x 24
Design Span (L): 65.85 ft.
Clear Span: 64.85 ft.
Total Span: 66.85 ft.
Bearing (lb): 12 in.
Live Load: 700 plf
Selfweight: 4539.0 lbs
Dist. Selfweight: 68.93 plf
Total Weight: 4607.9 lbs
CV Volume Factor 0.763b - - - - -
Beam Design Mike Cantor Belfast, Maine 2022A763
12/8/2022 1
b = 12.250 in.
d = 24.000 in.
A = 12.250 x 24.000 = 294.00 in.2
Sx = (12.250)(24.000)2/6 = 1176.00 in.3
Sy = (12.250)2(24.000)/6 = 600.25 in.3
Ix = (12.250)(24.000)3/12 = 14112.00 in.4
Iy = (12.250)3(24.000)/12 = 3676.53 in.4
12/8/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [294.00 x (790.20 + 12)] x (12 in./ft.)3 = 136.49 ft3
Volumespan = N[A x L] = 1 x [294.00 x 790.20] x (12 in./ft.)3 = 134.44 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 136.49 = 4607.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 134.44 = 4539.0 lbs
Distributed Self Weight (ws) = = 68.93 plf
700 plf
  ws = 68.93 plf
65.85 ft.
64.85 ft.
66.85 ft.
28208.33 lbs
28208.33 lbs
12/8/2022 3
CV = = 0.763
CV = 0.763 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.763) = 2105.4 psi
fb = = 4667.7 psi
 fb = 4667.7 psi > Fbx' = 2105.4 psi  (CSI = 2.22)   ➜  NG
12/8/2022 4
fv* = = 133.16 psi
 fv* = 133.16 psi < Fvx' = 304.75 psi  (CSI = 0.44)   ➜  OK
fv = = 141.77 psi
 fv = 141.77 psi < Fvx' = 304.75 psi  (CSI = 0.47)   ➜  OK
12/8/2022 5
ΔLL = = 11.66 in.
(L/d)LL = 790.20 / 11.66 = 68
 ΔLL = 11.66 in = L/68 > L/360   ➜  NG
ΔTL = = 14.06 in.
(L/d)TL = 790.20 / 14.06 = 56
 ΔTL = 14.06 in = L/56 > L/240   ➜  NG
fc⊥ = = 191.9 psi
 fc⊥ = 191.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.30)   ➜  OK
12/8/2022 6
