Beam Design - Restoration Barn
Size: 12.25 x 42
Design Span (L): 65.85 ft.
Clear Span: 64.85 ft.
Total Span: 66.85 ft.
Bearing (lb): 12 in.
Live Load: 700 plf
Selfweight: 15886.4 lbs
Dist. Selfweight: 241.25 plf
Total Weight: 16127.7 lbs
CV Volume Factor 0.721b - - - - -
Beam Design Mike Cantor Belfast, Maine 2022A761
12/8/2022 1
b = 12.250 in.
d = 42.000 in.
A = 12.250 x 42.000 = 514.50 in.2
Sx = (12.250)(42.000)2/6 = 3601.50 in.3
Sy = (12.250)2(42.000)/6 = 1050.44 in.3
Ix = (12.250)(42.000)3/12 = 75631.50 in.4
Iy = (12.250)3(42.000)/12 = 6433.93 in.4
12/8/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [514.50 x (790.20 + 12)] x (12 in./ft.)3 = 477.70 ft3
Volumespan = N[A x L] = 2 x [514.50 x 790.20] x (12 in./ft.)3 = 470.55 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 477.70 = 16127.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 470.55 = 15886.4 lbs
Distributed Self Weight (ws) = = 241.25 plf
700 plf
  ws = 241.25 plf
65.85 ft.
64.85 ft.
66.85 ft.
33968.22 lbs
33968.22 lbs
12/8/2022 3
CV = = 0.721
CV = 0.721 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.721) = 1990.8 psi
fb = = 917.7 psi
 fb = 917.7 psi < Fbx' = 1990.8 psi  (CSI = 0.46)   ➜  OK
12/8/2022 4
fv* = = 43.59 psi
 fv* = 43.59 psi < Fvx' = 304.75 psi  (CSI = 0.14)   ➜  OK
fv = = 48.78 psi
 fv = 48.78 psi < Fvx' = 304.75 psi  (CSI = 0.16)   ➜  OK
12/8/2022 5
ΔLL = = 1.09 in.
(L/d)LL = 790.20 / 1.09 = 727
 ΔLL = 1.09 in = L/727 < L/360   ➜  OK
ΔTL = = 1.58 in.
(L/d)TL = 790.20 / 1.58 = 500
 ΔTL = 1.58 in = L/500 < L/240   ➜  OK
fc⊥ = = 115.5 psi
 fc⊥ = 115.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.18)   ➜  OK
12/8/2022 6
