Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 400 lbs
Dead Load: 75 lbs
Selfweight: 80.8 lbs
Dist. Selfweight: 5.88 plf
Total Weight: 82.3 lbs
Beam Design 2022A76
2/11/2022 1
Beam Design 2022A76
2/11/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [8.25 x (165.00 + 3)] x (12 in./ft.)3 = 2.41 ft3
Volumespan = N[A x L] = 3 x [8.25 x 165.00] x (12 in./ft.)3 = 2.36 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.41 = 82.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.36 = 80.8 lbs
Distributed Self Weight (ws) = = 5.88 plf
400 lbs
75 lbs
ws = 5.88 plf
13.75 ft.
13.50 ft.
278.65 lbs
278.65 lbs
Beam Design 2022A76
2/11/2022 3
fb = = 937.1 psi
 fb = 937.1 psi < Fbx' = 1170.0 psi  (CSI = 0.80)   ➜  OK
Beam Design 2022A76
2/11/2022 4
fv* = = 16.68 psi
 fv* = 16.68 psi < Fvx' = 180.00 psi  (CSI = 0.09)   ➜  OK
fv = = 16.84 psi
 fv = 16.84 psi < Fvx' = 180.00 psi  (CSI = 0.09)   ➜  OK
Beam Design 2022A76
2/11/2022 5
ΔLL =   =   = 0.38 in.
(L/d)LL = 165.00 / 0.38 = 440
 ΔLL = 0.38 in = L/440 < L/360   ➜  OK
ΔTL =   =   = 0.49 in.
(L/d)TL = 165.00 / 0.49 = 335
 ΔTL = 0.49 in = L/335 < L/240   ➜  OK
fc⊥ = = 20.6 psi
 fc⊥ = 20.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.03)   ➜  OK
Beam Design 2022A76
2/11/2022 6
