Beam Design - Restoration Barn TieRd Beam
Size: 12.25 x 42
Design Span (L): 61.00 ft.
Clear Span: 60.00 ft.
Total Span: 62.00 ft.
Bearing (lb): 12 in.
Live Load: 700 plf
Selfweight: 7358.2 lbs
Dist. Selfweight: 120.63 plf
Total Weight: 7478.8 lbs
CV Volume Factor 0.727b - - - - -
Beam Design Mike Cantor Belfast, Maine 2022A754
12/6/2022 1
b = 12.250 in.
d = 42.000 in.
A = 12.250 x 42.000 = 514.50 in.2
Sx = (12.250)(42.000)2/6 = 3601.50 in.3
Sy = (12.250)2(42.000)/6 = 1050.44 in.3
Ix = (12.250)(42.000)3/12 = 75631.50 in.4
Iy = (12.250)3(42.000)/12 = 6433.93 in.4
12/6/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [514.50 x (732.00 + 12)] x (12 in./ft.)3 = 221.52 ft3
Volumespan = N[A x L] = 1 x [514.50 x 732.00] x (12 in./ft.)3 = 217.95 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 221.52 = 7478.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 217.95 = 7358.2 lbs
Distributed Self Weight (ws) = = 120.63 plf
700 plf
  ws = 120.63 plf
61.00 ft.
60.00 ft.
62.00 ft.
27764.40 lbs
27764.40 lbs
12/6/2022 3
CV = = 0.727
CV = 0.727 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.727) = 2006.1 psi
fb = = 1388.0 psi
 fb = 1388.0 psi < Fbx' = 2006.1 psi  (CSI = 0.69)   ➜  OK
12/6/2022 4
fv* = = 70.50 psi
 fv* = 70.50 psi < Fvx' = 304.75 psi  (CSI = 0.23)   ➜  OK
fv = = 79.64 psi
 fv = 79.64 psi < Fvx' = 304.75 psi  (CSI = 0.26)   ➜  OK
12/6/2022 5
ΔLL = = 1.60 in.
(L/d)LL = 732.00 / 1.60 = 457
 ΔLL = 1.60 in = L/457 < L/360   ➜  OK
ΔTL = = 2.05 in.
(L/d)TL = 732.00 / 2.05 = 357
 ΔTL = 2.05 in = L/357 < L/240   ➜  OK
fc⊥ = = 188.9 psi
 fc⊥ = 188.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.29)   ➜  OK
12/6/2022 6
