Beam Design - Restoration Barn TieRd Beam
Size: 12.25 x 24
Design Span (L): 61.00 ft.
Clear Span: 60.00 ft.
Total Span: 62.00 ft.
Bearing (lb): 12 in.
Live Load: 700 plf
Selfweight: 4204.7 lbs
Dist. Selfweight: 68.93 plf
Total Weight: 4273.6 lbs
CV Volume Factor 0.769b - - - - -
Beam Design Mike Cantor Belfast, Maine 2022A752
12/6/2022 1
b = 12.250 in.
d = 24.000 in.
A = 12.250 x 24.000 = 294.00 in.2
Sx = (12.250)(24.000)2/6 = 1176.00 in.3
Sy = (12.250)2(24.000)/6 = 600.25 in.3
Ix = (12.250)(24.000)3/12 = 14112.00 in.4
Iy = (12.250)3(24.000)/12 = 3676.53 in.4
12/6/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [294.00 x (732.00 + 12)] x (12 in./ft.)3 = 126.58 ft3
Volumespan = N[A x L] = 1 x [294.00 x 732.00] x (12 in./ft.)3 = 124.54 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 126.58 = 4273.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 124.54 = 4204.7 lbs
Distributed Self Weight (ws) = = 68.93 plf
700 plf
  ws = 68.93 plf
61.00 ft.
60.00 ft.
62.00 ft.
26161.80 lbs
26161.80 lbs
12/6/2022 3
CV = = 0.769
CV = 0.769 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.769) = 2121.5 psi
fb = = 4005.4 psi
 fb = 4005.4 psi > Fbx' = 2121.5 psi  (CSI = 1.89)   ➜  NG
12/6/2022 4
fv* = = 122.71 psi
 fv* = 122.71 psi < Fvx' = 304.75 psi  (CSI = 0.40)   ➜  OK
fv = = 131.33 psi
 fv = 131.33 psi < Fvx' = 304.75 psi  (CSI = 0.43)   ➜  OK
12/6/2022 5
ΔLL = = 8.58 in.
(L/d)LL = 732.00 / 8.58 = 85
 ΔLL = 8.58 in = L/85 > L/360   ➜  NG
ΔTL = = 10.35 in.
(L/d)TL = 732.00 / 10.35 = 71
 ΔTL = 10.35 in = L/71 > L/240   ➜  NG
fc⊥ = = 178.0 psi
 fc⊥ = 178.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.27)   ➜  OK
12/6/2022 6
