Size: 3.125 x 18
Design Span (L): 29.58 ft.
Clear Span: 29.17 ft.
Total Span: 30.00 ft.
Bearing (lb): 5 in.
Live Load: 320 plf
Dead Load: 240 plf
Selfweight: 390.1 lbs
Dist. Selfweight: 13.19 plf
Total Weight: 395.6 lbs
CL Beam Stability Factor 0.984 - - - - -
CV Volume Factor 0.975b - - - - -
Beam Design 2022A751
12/5/2022 1
b = 3.125 in.
d = 18.000 in.
A = 3.125 x 18.000 = 56.25 in.2
Sx = (3.125)(18.000)2/6 = 168.75 in.3
Sy = (3.125)2(18.000)/6 = 29.30 in.3
Ix = (3.125)(18.000)3/12 = 1518.75 in.4
Iy = (3.125)3(18.000)/12 = 45.78 in.4
12/5/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [56.25 x (355.00 + 5)] x (12 in./ft.)3 = 11.72 ft3
Volumespan = N[A x L] = 1 x [56.25 x 355.00] x (12 in./ft.)3 = 11.56 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 11.72 = 395.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 11.56 = 390.1 lbs
Distributed Self Weight (ws) = = 13.19 plf
320 plf
240 plf
  ws = 13.19 plf
29.58 ft.
29.17 ft.
30.00 ft.
8597.72 lbs
8597.72 lbs
12/5/2022 3
lu/d = = 1.33
Rb = = 9.55
 Rb = 9.55 < 50   ➜  OK
12/5/2022 4
FbE = = 11193.07 psi
CL =   = 0.984
CV = = 0.975
CV = 0.975 < CL = 0.984
Fbx' = (2400)(1.15)(1)(1)(0.975) = 2690.9 psi
fb = = 4458.9 psi
 fb = 4458.9 psi > Fbx' = 2690.9 psi  (CSI = 1.66)   ➜  NG
fv* = = 203.16 psi
12/5/2022 5
 fv* = 203.16 psi < Fvx' = 304.75 psi  (CSI = 0.67)   ➜  OK
fv = = 226.09 psi
 fv = 226.09 psi < Fvx' = 304.75 psi  (CSI = 0.74)   ➜  OK
ΔLL = = 2.02 in.
(L/d)LL = 355.00 / 2.02 = 176
 ΔLL = 2.02 in = L/176 > L/360   ➜  NG
ΔTL = = 3.61 in.
(L/d)TL = 355.00 / 3.61 = 98
 ΔTL = 3.61 in = L/98 > L/240   ➜  NG
12/5/2022 6
Ab = b x lb = 3.125 x 5 = 15.63 in2
fc⊥ = = 550.3 psi
 fc⊥ = 550.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.85)   ➜  OK
12/5/2022 7
