Size: 3.5 x 6
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 550 lbs
Dead Load: 75 lbs
Selfweight: 67.7 lbs
Dist. Selfweight: 4.92 plf
Total Weight: 68.9 lbs
Beam Design 2022A75
2/11/2022 1
d = 6.000 in.
A = 3.500 x 6.000 = 21.00 in.2
Sx = (3.500)(6.000)2/6 = 21.00 in.3
Sy = (3.500)2(6.000)/6 = 12.25 in.3
Ix = (3.500)(6.000)3/12 = 63.00 in.4
Iy = (3.500)3(6.000)/12 = 21.44 in.4
Beam Design 2022A75
2/11/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [21.00 x (165.00 + 3)] x (12 in./ft.)3 = 2.04 ft3
Volumespan = N[A x L] = 1 x [21.00 x 165.00] x (12 in./ft.)3 = 2.01 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 2.04 = 68.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 2.01 = 67.7 lbs
Distributed Self Weight (ws) = = 4.92 plf
550 lbs
75 lbs
  ws = 4.92 plf
13.75 ft.
13.50 ft.
346.96 lbs
346.96 lbs
Beam Design 2022A75
2/11/2022 3
fb = = 1294.2 psi
 fb = 1294.2 psi < Fbx' = 2400.0 psi  (CSI = 0.54)   ➜  OK
Beam Design 2022A75
2/11/2022 4
fv* = = 24.56 psi
 fv* = 24.56 psi < Fvx' = 265.00 psi  (CSI = 0.09)   ➜  OK
fv = = 24.74 psi
 fv = 24.74 psi < Fvx' = 265.00 psi  (CSI = 0.09)   ➜  OK
Beam Design 2022A75
2/11/2022 5
ΔLL =   =   = 0.45 in.
(L/d)LL = 165.00 / 0.45 = 364
 ΔLL = 0.45 in = L/364 < L/360   ➜  OK
ΔTL =   =   = 0.55 in.
(L/d)TL = 165.00 / 0.55 = 300
 ΔTL = 0.55 in = L/300 < L/240   ➜  OK
fc⊥ = = 33.0 psi
 fc⊥ = 33.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.05)   ➜  OK
Beam Design 2022A75
2/11/2022 6
