Grade: SP No.3
Size: 4 x 8
Design Span (L): 26.75 ft.
Clear Span: 26.50 ft.
Total Span: 27.00 ft.
Live Load: 1 plf
Dead Load: 25 plf
Selfweight: 351.9 lbs
Dist. Selfweight: 13.16 plf
Total Weight: 355.2 lbs
CF Size Factor 1.1 1 - 1 - -
Beam Design 2022A745
12/2/2022 1
SP No.3 525 325 175 565 775 1300000 470000 0.55
12/2/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [25.38 x (321.00 + 3)] x (12 in./ft.)3 = 9.52 ft3
Volumespan = N[A x L] = 2 x [25.38 x 321.00] x (12 in./ft.)3 = 9.43 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 9.52 = 355.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 9.43 = 351.9 lbs
Distributed Self Weight (ws) = = 13.16 plf
1 plf
25 plf
ws = 13.16 plf
26.75 ft.
26.50 ft.
27.00 ft.
528.61 lbs
528.61 lbs
12/2/2022 3
Fbx' = (525)(1.00)(1)(1)(1)(1.1)(1)(1) = 577.5 psi
fb = = 685.4 psi
 fb = 685.4 psi > Fbx' = 577.5 psi  (CSI = 1.19)   ➜  NG
12/2/2022 4
fv* = = 14.78 psi
 fv* = 14.78 psi < Fvx' = 175.00 psi  (CSI = 0.08)   ➜  OK
fv = = 15.48 psi
 fv = 15.48 psi < Fvx' = 175.00 psi  (CSI = 0.09)   ➜  OK
12/2/2022 5
ΔLL = = 0.04 in.
(L/d)LL = 321.00 / 0.04 = 8052
 ΔLL = 0.04 in = L/8052 < L/360   ➜  OK
ΔTL = = 1.56 in.
(L/d)TL = 321.00 / 1.56 = 206
 ΔTL = 1.56 in = L/206 > L/240   ➜  NG
fc⊥ = = 25.2 psi
 fc⊥ = 25.2 psi < Fc⊥x' = 565.00 psi  (CSI = 0.04)   ➜  OK
12/2/2022 6
