Size: 12.25 x 60
Design Span (L): 61.00 ft.
Clear Span: 60.00 ft.
Total Span: 62.00 ft.
Bearing (lb): 12 in.
Live Load: 600 plf
Selfweight: 10511.7 lbs
Dist. Selfweight: 172.32 plf
Total Weight: 10684.0 lbs
CV Volume Factor 0.701b - - - - -
Beam Design 2022A742
12/1/2022 1
b = 12.250 in.
d = 60.000 in.
A = 12.250 x 60.000 = 735.00 in.2
Sx = (12.250)(60.000)2/6 = 7350.00 in.3
Sy = (12.250)2(60.000)/6 = 1500.63 in.3
Ix = (12.250)(60.000)3/12 = 220500.00 in.4
Iy = (12.250)3(60.000)/12 = 9191.33 in.4
12/1/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [735.00 x (732.00 + 12)] x (12 in./ft.)3 = 316.46 ft3
Volumespan = N[A x L] = 1 x [735.00 x 732.00] x (12 in./ft.)3 = 311.35 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 316.46 = 10684.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 311.35 = 10511.7 lbs
Distributed Self Weight (ws) = = 172.32 plf
600 plf
  ws = 172.32 plf
61.00 ft.
60.00 ft.
62.00 ft.
26267.01 lbs
26267.01 lbs
12/1/2022 3
CV = = 0.701
CV = 0.701 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.701) = 1935.8 psi
fb = = 643.4 psi
 fb = 643.4 psi < Fbx' = 1935.8 psi  (CSI = 0.33)   ➜  OK
12/1/2022 4
fv* = = 44.10 psi
 fv* = 44.10 psi < Fvx' = 304.75 psi  (CSI = 0.14)   ➜  OK
fv = = 52.74 psi
 fv = 52.74 psi < Fvx' = 304.75 psi  (CSI = 0.17)   ➜  OK
12/1/2022 5
ΔLL = = 0.47 in.
(L/d)LL = 732.00 / 0.47 = 1554
 ΔLL = 0.47 in = L/1554 < L/180   ➜  OK
ΔTL = = 0.67 in.
(L/d)TL = 732.00 / 0.67 = 1101
 ΔTL = 0.67 in = L/1101 < L/120   ➜  OK
fc⊥ = = 178.7 psi
 fc⊥ = 178.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.27)   ➜  OK
12/1/2022 6
