Size: 3.5 x 6
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 500 lbs
Dead Load: 75 lbs
Selfweight: 67.7 lbs
Dist. Selfweight: 4.92 plf
Total Weight: 68.9 lbs
Orientation: Horizontal
Cfu Flat Use Factor 1.147c - - - - -
Beam Design 2022A74
2/11/2022 1
d = 6.000 in.
A = 3.500 x 6.000 = 21.00 in.2
Sx = (3.500)(6.000)2/6 = 21.00 in.3
Sy = (3.500)2(6.000)/6 = 12.25 in.3
Ix = (3.500)(6.000)3/12 = 63.00 in.4
Iy = (3.500)3(6.000)/12 = 21.44 in.4
Beam Design 2022A74
2/11/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [21.00 x (165.00 + 3)] x (12 in./ft.)3 = 2.04 ft3
Volumespan = N[A x L] = 1 x [21.00 x 165.00] x (12 in./ft.)3 = 2.01 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 2.04 = 68.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 2.01 = 67.7 lbs
Distributed Self Weight (ws) = = 4.92 plf
500 lbs
75 lbs
  ws = 4.92 plf
13.75 ft.
13.50 ft.
321.96 lbs
321.96 lbs
Beam Design 2022A74
2/11/2022 3
Cfu = = 1.147
Fby' = (1450)(1.00)(1)(1)(1)(1.147) = 1662.7 psi
fb = = 2050.2 psi
 fb = 2050.2 psi > Fby' = 1662.7 psi  (CSI = 1.23)   ➜  NG
Beam Design 2022A74
2/11/2022 4
Fvy' = (230)(1.00)(1)(1) = 265.00 psi
fv* = = 22.85 psi
 fv* = 22.85 psi < Fvy' = 230.00 psi  (CSI = 0.10)   ➜  OK
fv = = 22.95 psi
 fv = 22.95 psi < Fvy' = 230.00 psi  (CSI = 0.10)   ➜  OK
Ey' = Ey(CM)(Ct) = 1600000(1)(1) = 1600000 psi
Beam Design 2022A74
2/11/2022 5
ΔLL =   =   = 1.36 in.
(L/d)LL = 165.00 / 1.36 = 121
 ΔLL = 1.36 in = L/121 > L/360   ➜  NG
ΔTL =   =   = 1.68 in.
(L/d)TL = 165.00 / 1.68 = 98
 ΔTL = 1.68 in = L/98 > L/240   ➜  NG
Fc⊥y' = (560)(1)(1) = 560.00 psi
Ab = d x lb = 6 x 3 = 18.00 in2
fc⊥ = = 17.9 psi
 fc⊥ = 17.9 psi < Fc⊥y' = 560.00 psi  (CSI = 0.03)   ➜  OK
Beam Design 2022A74
2/11/2022 6
