Size: 2.5 x 18
Design Span (L): 18.75 ft.
Clear Span: 18.50 ft.
Total Span: 19.00 ft.
Live Load: 320 lbs
Dead Load: 80 lbs
Selfweight: 395.6 lbs
Dist. Selfweight: 21.10 plf
Total Weight: 400.9 lbs
Beam Design 2022A736
11/21/2022 1
b = 2.500 in.
d = 18.000 in.
A = 2.500 x 18.000 = 45.00 in.2
Sx = (2.500)(18.000)2/6 = 135.00 in.3
Sy = (2.500)2(18.000)/6 = 18.75 in.3
Ix = (2.500)(18.000)3/12 = 1215.00 in.4
Iy = (2.500)3(18.000)/12 = 23.44 in.4
11/21/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [45.00 x (225.00 + 3)] x (12 in./ft.)3 = 11.88 ft3
Volumespan = N[A x L] = 2 x [45.00 x 225.00] x (12 in./ft.)3 = 11.72 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 11.88 = 400.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 11.72 = 395.6 lbs
Distributed Self Weight (ws) = = 21.10 plf
320 lbs
80 lbs
  ws = 21.10 plf
18.75 ft.
18.50 ft.
19.00 ft.
400.46 lbs
400.46 lbs
11/21/2022 3
fb = = 124.5 psi
 fb = 124.5 psi < Fbx' = 2760.0 psi  (CSI = 0.05)   ➜  OK
11/21/2022 4
fv* = = 6.10 psi
 fv* = 6.10 psi < Fvx' = 304.75 psi  (CSI = 0.02)   ➜  OK
fv = = 6.63 psi
 fv = 6.63 psi < Fvx' = 304.75 psi  (CSI = 0.02)   ➜  OK
11/21/2022 5
ΔLL =   =   = 0.02 in.
(L/d)LL = 225.00 / 0.02 = 12960
 ΔLL = 0.02 in = L/12960 < L/360   ➜  OK
ΔTL =   =   = 0.04 in.
(L/d)TL = 225.00 / 0.04 = 6407
 ΔTL = 0.04 in = L/6407 < L/240   ➜  OK
fc⊥ = = 26.7 psi
 fc⊥ = 26.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.04)   ➜  OK
11/21/2022 6
