Grade: SP DSS
Live Load: 198.8 plf
Dead Load: 49 plf
Selfweight: 51.4 lbs
Dist. Selfweight: 4.37 plf
Total Weight: 52.5 lbs
Beam Design Simmons 2022A734
11/21/2022 1
11/21/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (141.00 + 3)] x (12 in./ft.)3 = 1.41 ft3
Volumespan = N[A x L] = 1 x [16.88 x 141.00] x (12 in./ft.)3 = 1.38 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.41 = 52.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.38 = 51.4 lbs
198.8 plf
49 plf
ws = 4.37 plf
1513.05 lbs
1513.05 lbs
11/21/2022 3
fb = = 1650.5 psi
 fb = 1650.5 psi < Fbx' = 2070.0 psi  (CSI = 0.80)   ➜  OK
11/21/2022 4
fv* = = 110.68 psi
 fv* = 110.68 psi < Fvx' = 201.25 psi  (CSI = 0.55)   ➜  OK
fv = = 131.69 psi
 fv = 131.69 psi < Fvx' = 201.25 psi  (CSI = 0.65)   ➜  OK
11/21/2022 5
ΔLL = = 0.25 in.
(L/d)LL = 141.00 / 0.25 = 559
 ΔLL = 0.25 in = L/559 < L/360   ➜  OK
ΔTL = = 0.32 in.
(L/d)TL = 141.00 / 0.32 = 441
 ΔTL = 0.32 in = L/441 < L/240   ➜  OK
fc⊥ = = 336.2 psi
 fc⊥ = 336.2 psi < Fc⊥x' = 660.00 psi  (CSI = 0.51)   ➜  OK
11/21/2022 6
