Grade: SPF No.2
Selfweight: 98.8 lbs
Dist. Selfweight: 8.41 plf
Total Weight: 100.9 lbs
Beam Design 2022A733
11/18/2022 1
11/18/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (141.00 + 3)] x (12 in./ft.)3 = 3.47 ft3
Volumespan = N[A x L] = 3 x [13.88 x 141.00] x (12 in./ft.)3 = 3.40 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 3.47 = 100.9 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 3.40 = 98.8 lbs
Distributed Self Weight (ws) = = 8.41 plf
ws = 8.41 plf
1100.47 lbs
1100.47 lbs
11/18/2022 3
Fbx' = (875)(1.15)(1)(1)(1)(1.1)(1)(1) = 1106.9 psi
fb = = 591.9 psi
 fb = 591.9 psi < Fbx' = 1106.9 psi  (CSI = 0.53)   ➜  OK
11/18/2022 4
fv* = = 33.74 psi
 fv* = 33.74 psi < Fvx' = 155.25 psi  (CSI = 0.22)   ➜  OK
fv = = 38.83 psi
 fv = 38.83 psi < Fvx' = 155.25 psi  (CSI = 0.25)   ➜  OK
11/18/2022 5
ΔLL = = 0.10 in.
(L/d)LL = 141.00 / 0.10 = 1366
 ΔLL = 0.10 in = L/1366 < L/360   ➜  OK
ΔTL = = 0.19 in.
(L/d)TL = 141.00 / 0.19 = 745
 ΔTL = 0.19 in = L/745 < L/240   ➜  OK
fc⊥ = = 81.5 psi
 fc⊥ = 81.5 psi < Fc⊥x' = 425.00 psi  (CSI = 0.19)   ➜  OK
11/18/2022 6
