Grade: DF Construction
Size: 2 x 4
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 120 plf
Selfweight: 9.7 lbs
Dist. Selfweight: 1.25 plf
Total Weight: 10.0 lbs
Orientation: Horizontal
Beam Design 2022A73
2/10/2022 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
DF Construction 1000 650 180 625 1650 1500000 550000 0.5
Beam Design 2022A73
2/10/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [5.25 x (93.00 + 3)] x (12 in./ft.)3 = 0.29 ft3
Volumespan = N[A x L] = 1 x [5.25 x 93.00] x (12 in./ft.)3 = 0.28 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.29 = 10.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.28 = 9.7 lbs
Distributed Self Weight (ws) = = 1.25 plf
120 plf
ws = 1.25 plf
7.75 ft.
7.50 ft.
784.99 lbs
784.99 lbs
Beam Design 2022A73
2/10/2022 3
Fby' = (1000)(1.15)(1)(0.8)(1)(1)(1.1)(1)(1) = 1012.0 psi
fb = = 13471.0 psi
 fb = 13471.0 psi > Fby' = 1012.0 psi  (CSI = 13.31)   ➜  NG
Beam Design 2022A73
2/10/2022 4
Fvy' = (180)(1.15)(1)(0.8)(1) = 165.60 psi
fv* = = 210.26 psi
 fv* = 210.26 psi > Fvy' = 165.60 psi  (CSI = 1.27)   ➜  NG
fv = = 217.27 psi
 fv = 217.27 psi > Fvy' = 165.60 psi  (CSI = 1.31)   ➜  NG
Ey' = Ey(CM)(Ct)(Ci) = 1500000(1)(0.9)(1) = 1350000 psi
Beam Design 2022A73
2/10/2022 5
ΔLL = = 7.33 in.
(L/d)LL = 93.00 / 7.33 = 13
 ΔLL = 7.33 in = L/13 > L/180   ➜  NG
ΔTL = = 11.99 in.
(L/d)TL = 93.00 / 11.99 = 8
 ΔTL = 11.99 in = L/8 > L/120   ➜  NG
Fc⊥y' = (625)(1)(0.8)(1) = 500.00 psi
Ab = d x lb = 3.5 x 3 = 10.50 in2
fc⊥ = = 74.8 psi
 fc⊥ = 74.8 psi < Fc⊥y' = 500.00 psi  (CSI = 0.15)   ➜  OK
Beam Design 2022A73
2/10/2022 6
