Design Span (L): 6.75 ft.
Clear Span: 6.50 ft.
Total Span: 7.00 ft.
Live Load: 314 plf
Dead Load: 103 plf
Selfweight: 59.1 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 61.2 lbs
Beam Design 210 S Cypress 2022A728
11/17/2022 1
11/17/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (81.00 + 3)] x (12 in./ft.)3 = 1.64 ft3
Volumespan = N[A x L] = 2 x [16.88 x 81.00] x (12 in./ft.)3 = 1.58 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.64 = 61.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.58 = 59.1 lbs
314 plf
103 plf
ws = 8.75 plf
6.75 ft.
6.50 ft.
7.00 ft.
1490.12 lbs
1490.12 lbs
11/17/2022 3
fb = = 459.8 psi
 fb = 459.8 psi < Fbx' = 862.5 psi  (CSI = 0.53)   ➜  OK
11/17/2022 4
fv* = = 46.12 psi
 fv* = 46.12 psi < Fvx' = 201.25 psi  (CSI = 0.23)   ➜  OK
fv = = 63.86 psi
 fv = 63.86 psi < Fvx' = 201.25 psi  (CSI = 0.32)   ➜  OK
11/17/2022 5
ΔLL = = 0.03 in.
(L/d)LL = 81.00 / 0.03 = 2752
 ΔLL = 0.03 in = L/2752 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 81.00 / 0.04 = 2030
 ΔTL = 0.04 in = L/2030 < L/240   ➜  OK
fc⊥ = = 165.6 psi
 fc⊥ = 165.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.29)   ➜  OK
11/17/2022 6
