Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Live Load: 340 plf
Dead Load: 255 plf
Selfweight: 177.4 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 180.4 lbs
Beam Design 2022A725
11/15/2022 1
11/15/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (177.00 + 3)] x (12 in./ft.)3 = 5.27 ft3
Volumespan = N[A x L] = 3 x [16.88 x 177.00] x (12 in./ft.)3 = 5.19 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 5.27 = 180.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 5.19 = 177.4 lbs
340 plf
255 plf
ws = 12.02 plf
14.75 ft.
14.50 ft.
15.00 ft.
4552.69 lbs
4552.69 lbs
11/15/2022 3
fb = = 2087.0 psi
 fb = 2087.0 psi > Fbx' = 900.0 psi  (CSI = 2.32)   ➜  NG
11/15/2022 4
fv* = = 115.78 psi
 fv* = 115.78 psi < Fvx' = 180.00 psi  (CSI = 0.64)   ➜  OK
fv = = 132.65 psi
 fv = 132.65 psi < Fvx' = 180.00 psi  (CSI = 0.74)   ➜  OK
11/15/2022 5
ΔLL = = 0.42 in.
(L/d)LL = 177.00 / 0.42 = 418
 ΔLL = 0.42 in = L/418 < L/360   ➜  OK
ΔTL = = 0.76 in.
(L/d)TL = 177.00 / 0.76 = 234
 ΔTL = 0.76 in = L/234 > L/240   ➜  NG
fc⊥ = = 337.2 psi
 fc⊥ = 337.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.54)   ➜  OK
11/15/2022 6
