Beam Design - KANE LN REMODEL
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Live Load: 45 plf
Dead Load: 123 plf
Selfweight: 145.8 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 148.3 lbs
Beam Design PETER TRUONG 27210 KANE LN. CONROE ,TX 77385 101
11/14/2022 1
11/14/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (177.00 + 3)] x (12 in./ft.)3 = 4.34 ft3
Volumespan = N[A x L] = 3 x [13.88 x 177.00] x (12 in./ft.)3 = 4.26 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.34 = 148.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.26 = 145.8 lbs
45 plf
123 plf
ws = 9.89 plf
14.75 ft.
14.50 ft.
15.00 ft.
1334.15 lbs
1334.15 lbs
11/14/2022 3
fb = = 904.6 psi
 fb = 904.6 psi < Fbx' = 1138.5 psi  (CSI = 0.79)   ➜  OK
11/14/2022 4
fv* = = 42.33 psi
 fv* = 42.33 psi < Fvx' = 207.00 psi  (CSI = 0.20)   ➜  OK
fv = = 47.28 psi
 fv = 47.28 psi < Fvx' = 207.00 psi  (CSI = 0.23)   ➜  OK
11/14/2022 5
ΔLL = = 0.10 in.
(L/d)LL = 177.00 / 0.10 = 1754
 ΔLL = 0.10 in = L/1754 < L/360   ➜  OK
ΔTL = = 0.40 in.
(L/d)TL = 177.00 / 0.40 = 444
 ΔTL = 0.40 in = L/444 < L/240   ➜  OK
fc⊥ = = 98.8 psi
 fc⊥ = 98.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.16)   ➜  OK
11/14/2022 6
