Beam Design - KANE LN REMODEL
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Quantity (N): 4
Live Load: 170 plf
Dead Load: 208 plf
Selfweight: 236.5 lbs
Dist. Selfweight: 16.03 plf
Total Weight: 240.5 lbs
Beam Design PETER THANH 27210 KANE LN. CONROE ,TX 77385 101
11/12/2022 1
11/12/2022 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (177.00 + 3)] x (12 in./ft.)3 = 7.03 ft3
Volumespan = N[A x L] = 4 x [16.88 x 177.00] x (12 in./ft.)3 = 6.91 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 7.03 = 240.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 6.91 = 236.5 lbs
170 plf
208 plf
ws = 16.03 plf
14.75 ft.
14.50 ft.
15.00 ft.
2955.25 lbs
2955.25 lbs
11/12/2022 3
fb = = 1016.0 psi
 fb = 1016.0 psi < Fbx' = 1035.0 psi  (CSI = 0.98)   ➜  OK
11/12/2022 4
fv* = = 56.37 psi
 fv* = 56.37 psi < Fvx' = 207.00 psi  (CSI = 0.27)   ➜  OK
fv = = 64.58 psi
 fv = 64.58 psi < Fvx' = 207.00 psi  (CSI = 0.31)   ➜  OK
11/12/2022 5
ΔLL = = 0.16 in.
(L/d)LL = 177.00 / 0.16 = 1114
 ΔLL = 0.16 in = L/1114 < L/360   ➜  OK
ΔTL = = 0.37 in.
(L/d)TL = 177.00 / 0.37 = 480
 ΔTL = 0.37 in = L/480 < L/240   ➜  OK
fc⊥ = = 164.2 psi
 fc⊥ = 164.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.26)   ➜  OK
11/12/2022 6
