Beam Design - Stable Residence
Species: Hem-Fir
Grade: HF No.2
Design Span (L): 8.50 ft.
Clear Span: 8.25 ft.
Total Span: 8.75 ft.
Live Load: 82 plf
Dead Load: 10 plf
Selfweight: 19.9 lbs
Dist. Selfweight: 2.34 plf
Total Weight: 20.5 lbs
Beam Design 2022A714
11/10/2022 1
G = 0.43
11/10/2022 2
= 30.99 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (102.00 + 3)] x (12 in./ft.)3 = 0.66 ft3
Volumespan = N[A x L] = 1 x [10.88 x 102.00] x (12 in./ft.)3 = 0.64 ft3
Total Weight (WT) = ρw x Volumetotal = 30.99 x 0.66 = 20.5 lbs
Self Weight (WS) = ρw x Volumespan = 30.99 x 0.64 = 19.9 lbs
Distributed Self Weight (ws) = = 2.34 plf
82 plf
10 plf
ws = 2.34 plf
8.50 ft.
8.25 ft.
8.75 ft.
412.74 lbs
412.74 lbs
11/10/2022 3
Fbx' = (850)(1.15)(1)(1)(1)(1.2)(1)(1) = 1173.0 psi
fb = = 778.1 psi
 fb = 778.1 psi < Fbx' = 1173.0 psi  (CSI = 0.66)   ➜  OK
11/10/2022 4
fv* = = 47.44 psi
 fv* = 47.44 psi < Fvx' = 167.32 psi  (CSI = 0.28)   ➜  OK
fv = = 55.30 psi
 fv = 55.30 psi < Fvx' = 167.32 psi  (CSI = 0.33)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1300000(0.9)(1)(1) = 1170000 psi
11/10/2022 5
ΔLL = = 0.17 in.
(L/d)LL = 102.00 / 0.17 = 590
 ΔLL = 0.17 in = L/590 < L/180   ➜  OK
ΔTL = = 0.20 in.
(L/d)TL = 102.00 / 0.20 = 513
 ΔTL = 0.20 in = L/513 < L/120   ➜  OK
fc⊥ = = 91.7 psi
 fc⊥ = 91.7 psi < Fc⊥x' = 271.35 psi  (CSI = 0.34)   ➜  OK
11/10/2022 6
