Beam Design - Stable Residence
Design Span (L): 8.50 ft.
Clear Span: 8.25 ft.
Total Span: 8.75 ft.
Live Load: 137 plf
Dead Load: 10 plf
Selfweight: 22.8 lbs
Dist. Selfweight: 2.68 plf
Total Weight: 23.4 lbs
Beam Design 2022A712
11/10/2022 1
11/10/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (102.00 + 3)] x (12 in./ft.)3 = 0.66 ft3
Volumespan = N[A x L] = 1 x [10.88 x 102.00] x (12 in./ft.)3 = 0.64 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 0.66 = 23.4 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 0.64 = 22.8 lbs
Distributed Self Weight (ws) = = 2.68 plf
137 plf
10 plf
ws = 2.68 plf
8.50 ft.
8.25 ft.
8.75 ft.
654.84 lbs
654.84 lbs
11/10/2022 3
fb = = 1234.4 psi
 fb = 1234.4 psi < Fbx' = 1242.0 psi  (CSI = 0.99)   ➜  OK
11/10/2022 4
fv* = = 75.27 psi
 fv* = 75.27 psi < Fvx' = 200.79 psi  (CSI = 0.37)   ➜  OK
fv = = 87.74 psi
 fv = 87.74 psi < Fvx' = 200.79 psi  (CSI = 0.44)   ➜  OK
11/10/2022 5
ΔLL = = 0.23 in.
(L/d)LL = 102.00 / 0.23 = 435
 ΔLL = 0.23 in = L/435 < L/180   ➜  OK
ΔTL = = 0.26 in.
(L/d)TL = 102.00 / 0.26 = 398
 ΔTL = 0.26 in = L/398 < L/120   ➜  OK
fc⊥ = = 145.5 psi
 fc⊥ = 145.5 psi < Fc⊥x' = 418.75 psi  (CSI = 0.35)   ➜  OK
11/10/2022 6
