Beam Design - Stable Residence
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Quantity (N): 5
Live Load: 600 plf
Dead Load: 20 plf
Selfweight: 255.5 lbs
Dist. Selfweight: 20.04 plf
Total Weight: 260.5 lbs
Beam Design 2022A711
11/10/2022 1
11/10/2022 2
Volumetotal = N[A x (L + lb)] = 5 x [16.88 x (153.00 + 3)] x (12 in./ft.)3 = 7.62 ft3
Volumespan = N[A x L] = 5 x [16.88 x 153.00] x (12 in./ft.)3 = 7.47 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 7.62 = 260.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 7.47 = 255.5 lbs
Distributed Self Weight (ws) = = 20.04 plf
600 plf
20 plf
ws = 20.04 plf
12.75 ft.
12.50 ft.
13.00 ft.
4160.27 lbs
4160.27 lbs
11/10/2022 3
fb = = 986.5 psi
 fb = 986.5 psi < Fbx' = 1035.0 psi  (CSI = 0.95)   ➜  OK
11/10/2022 4
fv* = = 61.87 psi
 fv* = 61.87 psi < Fvx' = 207.00 psi  (CSI = 0.30)   ➜  OK
fv = = 72.54 psi
 fv = 72.54 psi < Fvx' = 207.00 psi  (CSI = 0.35)   ➜  OK
11/10/2022 5
ΔLL = = 0.25 in.
(L/d)LL = 153.00 / 0.25 = 611
 ΔLL = 0.25 in = L/611 < L/180   ➜  OK
ΔTL = = 0.27 in.
(L/d)TL = 153.00 / 0.27 = 572
 ΔTL = 0.27 in = L/572 < L/120   ➜  OK
fc⊥ = = 184.9 psi
 fc⊥ = 184.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.30)   ➜  OK
11/10/2022 6
