Grade: SP Standard
Size: 2 x 4
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Selfweight: 13.3 lbs
Dist. Selfweight: 1.36 plf
Total Weight: 13.6 lbs
Orientation: Horizontal
Beam Design 2022A71
2/10/2022 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
SP Standard 475 275 175 565 1300 1200000 440000 0.55
Beam Design 2022A71
2/10/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [5.25 x (117.00 + 3)] x (12 in./ft.)3 = 0.36 ft3
Volumespan = N[A x L] = 1 x [5.25 x 117.00] x (12 in./ft.)3 = 0.36 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.36 = 13.6 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.36 = 13.3 lbs
Distributed Self Weight (ws) = = 1.36 plf
ws = 1.36 plf
9.75 ft.
9.50 ft.
10.00 ft.
881.80 lbs
881.80 lbs
Beam Design 2022A71
2/10/2022 3
Fby' = (475)(1.00)(1)(1)(1)(1)(1.1)(1)(1) = 522.5 psi
fb = = 19160.4 psi
 fb = 19160.4 psi > Fby' = 522.5 psi  (CSI = 36.67)   ➜  NG
Beam Design 2022A71
2/10/2022 4
Fvy' = (175)(1.00)(1)(1)(1) = 175.00 psi
fv* = = 239.35 psi
 fv* = 239.35 psi > Fvy' = 175.00 psi  (CSI = 1.37)   ➜  NG
fv = = 245.65 psi
 fv = 245.65 psi > Fvy' = 175.00 psi  (CSI = 1.40)   ➜  NG
Ey' = Ey(CM)(Ct)(Ci) = 1200000(1)(1)(1) = 1200000 psi
Beam Design 2022A71
2/10/2022 5
ΔLL = = 17.21 in.
(L/d)LL = 117.00 / 17.21 = 7
 ΔLL = 17.21 in = L/7 > L/180   ➜  NG
ΔTL = = 30.36 in.
(L/d)TL = 117.00 / 30.36 = 4
 ΔTL = 30.36 in = L/4 > L/120   ➜  NG
Fc⊥y' = (565)(1)(1)(1) = 565.00 psi
Ab = d x lb = 3.5 x 3 = 10.50 in2
fc⊥ = = 84.0 psi
 fc⊥ = 84.0 psi < Fc⊥y' = 565.00 psi  (CSI = 0.15)   ➜  OK
Beam Design 2022A71
2/10/2022 6
