Beam Design - 27210 KANE LN
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 80 plf
Dead Load: 20 plf
Selfweight: 32.1 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 33.0 lbs
Beam Design PETER TRUONG 17806 Placid Oak Ct. 101
11/10/2022 1
11/10/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (117.00 + 3)] x (12 in./ft.)3 = 0.96 ft3
Volumespan = N[A x L] = 1 x [13.88 x 117.00] x (12 in./ft.)3 = 0.94 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.96 = 33.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.94 = 32.1 lbs
80 plf
20 plf
ws = 3.30 plf
9.75 ft.
9.50 ft.
10.00 ft.
516.48 lbs
516.48 lbs
11/10/2022 3
Fbx' = (900)(1.15)(1)(0.8)(1)(1.1)(1)(1) = 910.8 psi
fb = = 688.6 psi
 fb = 688.6 psi < Fbx' = 910.8 psi  (CSI = 0.76)   ➜  OK
11/10/2022 4
Fvx' = (180)(1.15)(1)(0.8)(1) = 165.60 psi
fv* = = 45.83 psi
 fv* = 45.83 psi < Fvx' = 165.60 psi  (CSI = 0.28)   ➜  OK
fv = = 54.44 psi
 fv = 54.44 psi < Fvx' = 165.60 psi  (CSI = 0.33)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1600000(1)(0.9)(1) = 1440000 psi
11/10/2022 5
ΔLL = = 0.11 in.
(L/d)LL = 117.00 / 0.11 = 1025
 ΔLL = 0.11 in = L/1025 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 117.00 / 0.15 = 794
 ΔTL = 0.15 in = L/794 < L/240   ➜  OK
fc⊥ = = 114.8 psi
 fc⊥ = 114.8 psi < Fc⊥x' = 500.00 psi  (CSI = 0.23)   ➜  OK
11/10/2022 6
