Grade: SPF SS
Design Span (L): 19.67 ft.
Clear Span: 19.33 ft.
Total Span: 20.00 ft.
Bearing (lb): 4 in.
Live Load: 70 plf
Dead Load: 15 plf
Selfweight: 86.4 lbs
Dist. Selfweight: 4.39 plf
Total Weight: 87.9 lbs
CL Beam Stability Factor 0.872 - - - - -
Beam Design 2022A704
11/6/2022 1
11/6/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (236.00 + 4)] x (12 in./ft.)3 = 3.02 ft3
Volumespan = N[A x L] = 2 x [10.88 x 236.00] x (12 in./ft.)3 = 2.97 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 3.02 = 87.9 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.97 = 86.4 lbs
70 plf
15 plf
ws = 4.39 plf
19.67 ft.
19.33 ft.
893.96 lbs
893.96 lbs
11/6/2022 3
lu = Unbraced Length = 19.667 ft.
lu/d = = 32.55
le = 1.63lu + 3d = 1.63(236.0) + 3(7.25) = 406.44 in. = 33.87 ft.  (NDS Table 3.3.3)
Rb = = 18.09
 Rb = 18.09 < 50   ➜  OK
11/6/2022 4
FbE = = 2015.84 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1250)(1.15)(1)(1)(1.2)(1)(1) = 1725.00 psi
CL =   = 0.872
Fbx' = (1250)(1.15)(1)(1)(0.872)(1.2)(1)(1) = 1504.0 psi
fb = = 1973.5 psi
 fb = 1973.5 psi > Fbx' = 1504.0 psi  (CSI = 1.31)   ➜  NG
fv* = = 56.90 psi
 fv* = 56.90 psi < Fvx' = 155.25 psi  (CSI = 0.37)   ➜  OK
fv = = 60.63 psi
 fv = 60.63 psi < Fvx' = 155.25 psi  (CSI = 0.39)   ➜  OK
11/6/2022 5
ΔLL = = 1.65 in.
(L/d)LL = 236.00 / 1.65 = 143
 ΔLL = 1.65 in = L/143 > L/360   ➜  NG
ΔTL = = 2.11 in.
(L/d)TL = 236.00 / 2.11 = 112
 ΔTL = 2.11 in = L/112 > L/240   ➜  NG
fc⊥ = = 74.5 psi
 fc⊥ = 74.5 psi < Fc⊥x' = 425.00 psi  (CSI = 0.18)   ➜  OK
11/6/2022 6
