Beam Design - load Assessment
Design Span (L): 11.13 ft.
Clear Span: 10.38 ft.
Total Span: 11.88 ft.
Bearing (lb): 9 in.
Quantity (N): 4
Selfweight: 146.7 lbs
Dist. Selfweight: 13.18 plf
Total Weight: 156.5 lbs
Beam Design Mostafa Kechmy 4443 S Lenox 11273
10/29/2022 1
10/29/2022 2
Volumetotal = N[A x (L + lb)] = 4 x [13.88 x (133.50 + 9)] x (12 in./ft.)3 = 4.58 ft3
Volumespan = N[A x L] = 4 x [13.88 x 133.50] x (12 in./ft.)3 = 4.29 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.58 = 156.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.29 = 146.7 lbs
Distributed Self Weight (ws) = = 13.18 plf
ws = 13.18 plf
11.13 ft.
10.38 ft.
11.88 ft.
1117.33 lbs
1117.33 lbs
10/29/2022 3
fb = = 408.3 psi
 fb = 408.3 psi < Fbx' = 1138.5 psi  (CSI = 0.36)   ➜  OK
10/29/2022 4
fv* = = 24.37 psi
 fv* = 24.37 psi < Fvx' = 207.00 psi  (CSI = 0.12)   ➜  OK
fv = = 28.29 psi
 fv = 28.29 psi < Fvx' = 207.00 psi  (CSI = 0.14)   ➜  OK
10/29/2022 5
ΔLL = = 0.05 in.
(L/d)LL = 133.50 / 0.05 = 2453
 ΔLL = 0.05 in = L/2453 < L/360   ➜  OK
ΔTL = = 0.10 in.
(L/d)TL = 133.50 / 0.10 = 1303
 ΔTL = 0.10 in = L/1303 < L/240   ➜  OK
Ab = b x lb = 1.5 x 9 = 13.50 in2
fc⊥ = = 20.7 psi
 fc⊥ = 20.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.03)   ➜  OK
10/29/2022 6
