Grade: SP No.1
Design Span (L): 9.25 ft.
Clear Span: 9.00 ft.
Total Span: 9.50 ft.
Live Load: 600 plf
Selfweight: 121.4 lbs
Dist. Selfweight: 13.12 plf
Total Weight: 124.7 lbs
Beam Design Tibbetts 2022A697
10/28/2022 1
10/28/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (111.00 + 3)] x (12 in./ft.)3 = 3.34 ft3
Volumespan = N[A x L] = 3 x [16.88 x 111.00] x (12 in./ft.)3 = 3.25 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.34 = 124.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.25 = 121.4 lbs
600 plf
ws = 13.12 plf
9.25 ft.
9.00 ft.
9.50 ft.
3268.59 lbs
3268.59 lbs
10/28/2022 3
fb = = 930.4 psi
 fb = 930.4 psi < Fbx' = 1150.0 psi  (CSI = 0.81)   ➜  OK
10/28/2022 4
fv* = = 75.18 psi
 fv* = 75.18 psi < Fvx' = 201.25 psi  (CSI = 0.37)   ➜  OK
fv = = 94.30 psi
 fv = 94.30 psi < Fvx' = 201.25 psi  (CSI = 0.47)   ➜  OK
10/28/2022 5
ΔLL = = 0.12 in.
(L/d)LL = 111.00 / 0.12 = 959
 ΔLL = 0.12 in = L/959 < L/180   ➜  OK
ΔTL = = 0.13 in.
(L/d)TL = 111.00 / 0.13 = 837
 ΔTL = 0.13 in = L/837 < L/120   ➜  OK
fc⊥ = = 242.1 psi
 fc⊥ = 242.1 psi < Fc⊥x' = 565.00 psi  (CSI = 0.43)   ➜  OK
10/28/2022 6
