Beam Design - rafter
Grade: SPF SS
Design Span (L): 10.25 ft.
Clear Span: 10.00 ft.
Total Span: 10.50 ft.
Live Load: 68.7 plf
Dead Load: 16 plf
Selfweight: 35.0 lbs
Dist. Selfweight: 3.41 plf
Total Weight: 35.8 lbs
Beam Design d f SL Alden
10/24/2022 1
10/24/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (123.00 + 3)] x (12 in./ft.)3 = 1.23 ft3
Volumespan = N[A x L] = 1 x [16.88 x 123.00] x (12 in./ft.)3 = 1.20 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.23 = 35.8 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.20 = 35.0 lbs
Distributed Self Weight (ws) = = 3.41 plf
68.7 plf
16 plf
ws = 3.41 plf
10.25 ft.
10.00 ft.
10.50 ft.
462.58 lbs
462.58 lbs
10/24/2022 3
fb = = 438.9 psi
 fb = 438.9 psi < Fbx' = 1437.5 psi  (CSI = 0.31)   ➜  OK
10/24/2022 4
fv* = = 32.80 psi
 fv* = 32.80 psi < Fvx' = 155.25 psi  (CSI = 0.21)   ➜  OK
fv = = 40.14 psi
 fv = 40.14 psi < Fvx' = 155.25 psi  (CSI = 0.26)   ➜  OK
10/24/2022 5
ΔLL = = 0.06 in.
(L/d)LL = 123.00 / 0.06 = 1925
 ΔLL = 0.06 in = L/1925 < L/360   ➜  OK
ΔTL = = 0.08 in.
(L/d)TL = 123.00 / 0.08 = 1501
 ΔTL = 0.08 in = L/1501 < L/240   ➜  OK
fc⊥ = = 102.8 psi
 fc⊥ = 102.8 psi < Fc⊥x' = 425.00 psi  (CSI = 0.24)   ➜  OK
10/24/2022 6
