Size: 3.5 x 15
Design Span (L): 18.75 ft.
Clear Span: 18.50 ft.
Total Span: 19.00 ft.
Live Load: 340 plf
Dead Load: 170 plf
Selfweight: 230.8 lbs
Dist. Selfweight: 12.31 plf
Total Weight: 233.9 lbs
Beam Design 2022A69
2/10/2022 1
d = 15.000 in.
Beam Design 2022A69
2/10/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (225.00 + 3)] x (12 in./ft.)3 = 6.93 ft3
Volumespan = N[A x L] = 1 x [52.50 x 225.00] x (12 in./ft.)3 = 6.84 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.93 = 233.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.84 = 230.8 lbs
340 plf
170 plf
  ws = 12.31 plf
18.75 ft.
18.50 ft.
19.00 ft.
4961.93 lbs
4961.93 lbs
Beam Design 2022A69
2/10/2022 3
fb = = 2098.6 psi
 fb = 2098.6 psi < Fbx' = 2400.0 psi  (CSI = 0.87)   ➜  OK
Beam Design 2022A69
2/10/2022 4
fv* = = 121.25 psi
 fv* = 121.25 psi < Fvx' = 265.00 psi  (CSI = 0.46)   ➜  OK
fv = = 139.90 psi
 fv = 139.90 psi < Fvx' = 265.00 psi  (CSI = 0.53)   ➜  OK
Beam Design 2022A69
2/10/2022 5
ΔLL = = 0.53 in.
(L/d)LL = 225.00 / 0.53 = 422
 ΔLL = 0.53 in = L/422 < L/360   ➜  OK
ΔTL = = 0.82 in.
(L/d)TL = 225.00 / 0.82 = 274
 ΔTL = 0.82 in = L/274 < L/240   ➜  OK
fc⊥ = = 472.6 psi
 fc⊥ = 472.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.73)   ➜  OK
Beam Design 2022A69
2/10/2022 6
