Beam Design - Truss Support
Size: 6.75 x 10.5
Design Span (L): 23.50 ft.
Clear Span: 23.00 ft.
Total Span: 24.00 ft.
Live Load: 105 plf
Selfweight: 390.5 lbs
Dist. Selfweight: 16.62 plf
Total Weight: 398.8 lbs
CL Beam Stability Factor 0.979 - - - - -
CV Volume Factor 0.975b - - - - -
Beam Design Roger Murch 8054 Harmony Crescent 8054
10/23/2022 1
b = 6.750 in.
d = 10.500 in.
A = 6.750 x 10.500 = 70.88 in.2
Sx = (6.750)(10.500)2/6 = 124.03 in.3
Sy = (6.750)2(10.500)/6 = 79.73 in.3
Ix = (6.750)(10.500)3/12 = 651.16 in.4
Iy = (6.750)3(10.500)/12 = 269.10 in.4
10/23/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [70.88 x (282.00 + 6)] x (12 in./ft.)3 = 11.81 ft3
Volumespan = N[A x L] = 1 x [70.88 x 282.00] x (12 in./ft.)3 = 11.57 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 11.81 = 398.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 11.57 = 390.5 lbs
Distributed Self Weight (ws) = = 16.62 plf
105 plf
  ws = 16.62 plf
23.50 ft.
23.00 ft.
24.00 ft.
2359.40 lbs
2359.40 lbs
10/23/2022 3
lu = Unbraced Length = 23.500 ft.
lu/d = = 26.86
le = 1.63lu + 3d = 1.63(282.0) + 3(10.5) = 491.16 in. = 40.93 ft.  (NDS Table 3.3.3)
Rb = = 10.64
 Rb = 10.64 < 50   ➜  OK
10/23/2022 4
FbE = = 9011.47 psi
CL =   = 0.979
CV = = 0.975
CV = 0.975 < CL = 0.979
Fbx' = (2400)(1.15)(1)(1)(0.975) = 2690.7 psi
fb = = 1313.2 psi
 fb = 1313.2 psi < Fbx' = 2690.7 psi  (CSI = 0.49)   ➜  OK
fv* = = 45.25 psi
10/23/2022 5
 fv* = 45.25 psi < Fvx' = 304.75 psi  (CSI = 0.15)   ➜  OK
fv = = 48.89 psi
 fv = 48.89 psi < Fvx' = 304.75 psi  (CSI = 0.16)   ➜  OK
ΔLL = = 0.61 in.
(L/d)LL = 282.00 / 0.61 = 459
 ΔLL = 0.61 in = L/459 < L/180   ➜  OK
ΔTL = = 1.15 in.
(L/d)TL = 282.00 / 1.15 = 245
 ΔTL = 1.15 in = L/245 < L/120   ➜  OK
10/23/2022 6
fc⊥ = = 58.3 psi
 fc⊥ = 58.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.09)   ➜  OK
10/23/2022 7
