Design Span (L): 11.46 ft.
Clear Span: 11.17 ft.
Total Span: 11.75 ft.
Bearing (lb): 3.5 in.
Live Load: 70 plf
Dead Load: 40 plf
Selfweight: 75.5 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 77.4 lbs
Beam Design 2022A688
10/23/2022 1
10/23/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (137.50 + 3.5)] x (12 in./ft.)3 = 2.26 ft3
Volumespan = N[A x L] = 2 x [13.88 x 137.50] x (12 in./ft.)3 = 2.21 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.26 = 77.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.21 = 75.5 lbs
70 plf
40 plf
ws = 6.59 plf
11.46 ft.
11.17 ft.
684.95 lbs
684.95 lbs
10/23/2022 3
fb = = 536.7 psi
 fb = 536.7 psi < Fbx' = 1138.5 psi  (CSI = 0.47)   ➜  OK
10/23/2022 4
fv* = = 31.25 psi
 fv* = 31.25 psi < Fvx' = 207.00 psi  (CSI = 0.15)   ➜  OK
fv = = 36.11 psi
 fv = 36.11 psi < Fvx' = 207.00 psi  (CSI = 0.17)   ➜  OK
10/23/2022 5
ΔLL = = 0.09 in.
(L/d)LL = 137.50 / 0.09 = 1603
 ΔLL = 0.09 in = L/1603 < L/360   ➜  OK
ΔTL = = 0.14 in.
(L/d)TL = 137.50 / 0.14 = 963
 ΔTL = 0.14 in = L/963 < L/240   ➜  OK
fc⊥ = = 65.2 psi
 fc⊥ = 65.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.10)   ➜  OK
10/23/2022 6
