Species: Hem-Fir
Grade: HF SS
Size: 4 x 6
Design Span (L): 7.00 ft.
Clear Span: 6.00 ft.
Total Span: 8.00 ft.
Bearing (lb): 12 in.
Selfweight: 83.5 lbs
Dist. Selfweight: 11.93 plf
Total Weight: 95.4 lbs
Beam Design 2022A684
10/20/2022 1
G = 0.43
10/20/2022 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [19.25 x (84.00 + 12)] x (12 in./ft.)3 = 3.21 ft3
Volumespan = N[A x L] = 3 x [19.25 x 84.00] x (12 in./ft.)3 = 2.81 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 3.21 = 95.4 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 2.81 = 83.5 lbs
Distributed Self Weight (ws) = = 11.93 plf
ws = 11.93 plf
7.00 ft.
747.71 lbs
747.71 lbs
10/20/2022 3
Fbx' = (1400)(1.15)(1)(1)(1)(1.3)(1)(1) = 2093.0 psi
fb = = 259.5 psi
 fb = 259.5 psi < Fbx' = 2093.0 psi  (CSI = 0.12)   ➜  OK
10/20/2022 4
Fvx' = (150)(1.15)(1)(1)(1) = 172.50 psi
fv* = = 14.77 psi
 fv* = 14.77 psi < Fvx' = 172.50 psi  (CSI = 0.09)   ➜  OK
fv = = 16.99 psi
 fv = 16.99 psi < Fvx' = 172.50 psi  (CSI = 0.10)   ➜  OK
10/20/2022 5
ΔLL = = 0.02 in.
(L/d)LL = 84.00 / 0.02 = 3622
 ΔLL = 0.02 in = L/3622 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 84.00 / 0.04 = 1938
 ΔTL = 0.04 in = L/1938 < L/240   ➜  OK
Ab = b x lb = 3.5 x 12 = 42.00 in2
fc⊥ = = 5.9 psi
 fc⊥ = 5.9 psi < Fc⊥x' = 405.00 psi  (CSI = 0.01)   ➜  OK
10/20/2022 6
