Grade: DF No.1 & Btr
Size: 4 x 16
Design Span (L): 19.67 ft.
Clear Span: 19.33 ft.
Total Span: 20.00 ft.
Bearing (lb): 4 in.
Live Load: 400 plf
Dead Load: 120 plf
Selfweight: 490.5 lbs
Dist. Selfweight: 24.94 plf
Total Weight: 498.8 lbs
Beam Design 2022A683
10/20/2022 1
d = 15.000 in.
10/20/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [52.50 x (236.00 + 4)] x (12 in./ft.)3 = 14.58 ft3
Volumespan = N[A x L] = 2 x [52.50 x 236.00] x (12 in./ft.)3 = 14.34 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 14.58 = 498.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 14.34 = 490.5 lbs
Distributed Self Weight (ws) = = 24.94 plf
400 plf
120 plf
ws = 24.94 plf
19.67 ft.
19.33 ft.
5449.49 lbs
5449.49 lbs
10/20/2022 3
Fbx' = (1200)(1.15)(1)(1)(1)(1)(1)(1) = 1380.0 psi
fb = = 1204.4 psi
 fb = 1204.4 psi < Fbx' = 1380.0 psi  (CSI = 0.87)   ➜  OK
10/20/2022 4
fv* = = 66.82 psi
 fv* = 66.82 psi < Fvx' = 207.00 psi  (CSI = 0.32)   ➜  OK
fv = = 76.55 psi
 fv = 76.55 psi < Fvx' = 207.00 psi  (CSI = 0.37)   ➜  OK
10/20/2022 5
ΔLL = = 0.38 in.
(L/d)LL = 236.00 / 0.38 = 621
 ΔLL = 0.38 in = L/621 < L/180   ➜  OK
ΔTL = = 0.52 in.
(L/d)TL = 236.00 / 0.52 = 456
 ΔTL = 0.52 in = L/456 < L/120   ➜  OK
Ab = b x lb = 3.5 x 4 = 14.00 in2
fc⊥ = = 194.6 psi
 fc⊥ = 194.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.31)   ➜  OK
10/20/2022 6
