Design Span (L): 11.88 ft.
Clear Span: 11.75 ft.
Bearing (lb): 1.5 in.
Live Load: 60 plf
Dead Load: 10 plf
Selfweight: 42.7 lbs
Dist. Selfweight: 3.60 plf
Total Weight: 43.2 lbs
Beam Design 2022A682
10/20/2022 1
10/20/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (142.50 + 1.5)] x (12 in./ft.)3 = 1.16 ft3
Volumespan = N[A x L] = 1 x [13.88 x 142.50] x (12 in./ft.)3 = 1.14 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.16 = 43.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.14 = 42.7 lbs
60 plf
10 plf
ws = 3.60 plf
11.88 ft.
441.58 lbs
441.58 lbs
10/20/2022 3
fb = = 727.8 psi
 fb = 727.8 psi < Fbx' = 920.0 psi  (CSI = 0.79)   ➜  OK
10/20/2022 4
fv* = = 41.11 psi
 fv* = 41.11 psi < Fvx' = 201.25 psi  (CSI = 0.20)   ➜  OK
fv = = 47.24 psi
 fv = 47.24 psi < Fvx' = 201.25 psi  (CSI = 0.23)   ➜  OK
10/20/2022 5
ΔLL = = 0.19 in.
(L/d)LL = 142.50 / 0.19 = 735
 ΔLL = 0.19 in = L/735 < L/360   ➜  OK
ΔTL = = 0.24 in.
(L/d)TL = 142.50 / 0.24 = 599
 ΔTL = 0.24 in = L/599 < L/240   ➜  OK
fc⊥ = = 196.3 psi
 fc⊥ = 196.3 psi < Fc⊥x' = 565.00 psi  (CSI = 0.35)   ➜  OK
10/20/2022 6
