Beam Design - Hot Tub Beam -- Edge
Design Span (L): 8.46 ft.
Clear Span: 8.00 ft.
Total Span: 8.92 ft.
Bearing (lb): 5.5 in.
Live Load: 376.67 plf
Dead Load: 56.67 plf
Selfweight: 114.7 lbs
Dist. Selfweight: 13.56 plf
Total Weight: 120.9 lbs
Defl. Limits: 480|360
Notes: LL
Beam Design Dale Hansen 850 Edmondson Rd, Monroe, GA 2022A679
10/17/2022 1
10/17/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (101.50 + 5.5)] x (12 in./ft.)3 = 3.13 ft3
Volumespan = N[A x L] = 3 x [16.88 x 101.50] x (12 in./ft.)3 = 2.97 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 3.13 = 120.9 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 2.97 = 114.7 lbs
Distributed Self Weight (ws) = = 13.56 plf
376.67 plf
56.67 plf
ws = 13.56 plf
8.46 ft.
8.92 ft.
1992.37 lbs
1992.37 lbs
10/17/2022 3
lu/d = = 2.13
Rb = = 5.24
 Rb = 5.24 < 50   ➜  OK
10/17/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 510000(0.9)(1)(1) = 459000 psi
FbE = = 20053.40 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (750)(1.00)(1)(1)(1)(1)(1) = 750.00 psi
CL =   = 0.998
Fbx' = (750)(1.00)(1)(1)(0.998)(1)(1)(1) = 748.5 psi
fb = = 505.2 psi
 fb = 505.2 psi < Fbx' = 748.5 psi  (CSI = 0.67)   ➜  OK
fv* = = 43.58 psi
 fv* = 43.58 psi < Fvx' = 169.75 psi  (CSI = 0.26)   ➜  OK
fv = = 56.00 psi
 fv = 56.00 psi < Fvx' = 169.75 psi  (CSI = 0.33)   ➜  OK
10/17/2022 5
LL Allowable: L/480
TL Allowable: L/360
ΔLL = = 0.06 in.
(L/d)LL = 101.50 / 0.06 = 1574
 ΔLL = 0.06 in = L/1574 < L/480   ➜  OK
ΔTL = = 0.08 in.
(L/d)TL = 101.50 / 0.08 = 1327
 ΔTL = 0.08 in = L/1327 < L/360   ➜  OK
fc⊥ = = 80.5 psi
 fc⊥ = 80.5 psi < Fc⊥x' = 378.55 psi  (CSI = 0.21)   ➜  OK
10/17/2022 6
