Size: 5.5 x 10.5
Design Span (L): 16.50 ft.
Clear Span: 16.00 ft.
Total Span: 17.00 ft.
Selfweight: 223.4 lbs
Dist. Selfweight: 13.54 plf
Total Weight: 230.2 lbs
Beam Design 2022A676
10/14/2022 1
d = 10.500 in.
A = 5.500 x 10.500 = 57.75 in.2
Sx = (5.500)(10.500)2/6 = 101.06 in.3
Sy = (5.500)2(10.500)/6 = 52.94 in.3
Ix = (5.500)(10.500)3/12 = 530.58 in.4
Iy = (5.500)3(10.500)/12 = 145.58 in.4
10/14/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [57.75 x (198.00 + 6)] x (12 in./ft.)3 = 6.82 ft3
Volumespan = N[A x L] = 1 x [57.75 x 198.00] x (12 in./ft.)3 = 6.62 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.82 = 230.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.62 = 223.4 lbs
  ws = 13.54 plf
16.50 ft.
17.00 ft.
1602.59 lbs
1602.59 lbs
10/14/2022 3
fb = = 761.9 psi
 fb = 761.9 psi < Fbx' = 2760.0 psi  (CSI = 0.28)   ➜  OK
10/14/2022 4
fv* = = 36.12 psi
 fv* = 36.12 psi < Fvx' = 304.75 psi  (CSI = 0.12)   ➜  OK
fv = = 40.40 psi
 fv = 40.40 psi < Fvx' = 304.75 psi  (CSI = 0.13)   ➜  OK
10/14/2022 5
ΔLL = = 0.17 in.
(L/d)LL = 198.00 / 0.17 = 1134
 ΔLL = 0.17 in = L/1134 < L/360   ➜  OK
ΔTL = = 0.33 in.
(L/d)TL = 198.00 / 0.33 = 601
 ΔTL = 0.33 in = L/601 < L/240   ➜  OK
fc⊥ = = 48.6 psi
 fc⊥ = 48.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.07)   ➜  OK
10/14/2022 6
