Design Span (L): 17.88 ft.
Clear Span: 17.75 ft.
Total Span: 18.00 ft.
Bearing (lb): 1.5 in.
Selfweight: 138.5 lbs
Dist. Selfweight: 7.75 plf
Total Weight: 139.5 lbs
Beam Design 2022A67
2/8/2022 1
Beam Design 2022A67
2/8/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (214.50 + 1.5)] x (12 in./ft.)3 = 4.08 ft3
Volumespan = N[A x L] = 3 x [10.88 x 214.50] x (12 in./ft.)3 = 4.05 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.08 = 139.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.05 = 138.5 lbs
Distributed Self Weight (ws) = = 7.75 plf
ws = 7.75 plf
17.88 ft.
17.75 ft.
18.00 ft.
1644.74 lbs
1644.74 lbs
Beam Design 2022A67
2/8/2022 3
fb = = 2221.8 psi
 fb = 2221.8 psi > Fbx' = 1242.0 psi  (CSI = 1.79)   ➜  NG
Beam Design 2022A67
2/8/2022 4
fv* = = 70.02 psi
 fv* = 70.02 psi < Fvx' = 207.00 psi  (CSI = 0.34)   ➜  OK
fv = = 75.10 psi
 fv = 75.10 psi < Fvx' = 207.00 psi  (CSI = 0.36)   ➜  OK
Beam Design 2022A67
2/8/2022 5
ΔLL = = 1.00 in.
(L/d)LL = 214.50 / 1.00 = 214
 ΔLL = 1.00 in = L/214 < L/180   ➜  OK
ΔTL = = 1.84 in.
(L/d)TL = 214.50 / 1.84 = 117
 ΔTL = 1.84 in = L/117 > L/120   ➜  NG
fc⊥ = = 243.7 psi
 fc⊥ = 243.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.39)   ➜  OK
Beam Design 2022A67
2/8/2022 6
