Beam Design - HOT TUB BEAM
Design Span (L): 8.23 ft.
Clear Span: 8.00 ft.
Total Span: 8.46 ft.
Bearing (lb): 2.75 in.
Quantity (N): 4
Live Load: 613.33 plf
Dead Load: 78.33 plf
Selfweight: 122.4 lbs
Dist. Selfweight: 14.87 plf
Total Weight: 125.8 lbs
Defl. Limits: 480|360
Notes: Hot Tub LL
Beam Design Dale Hansen 850 Edmondson Rd, Monroe, GA 2022A666
10/11/2022 1
10/11/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 4 x [13.88 x (98.75 + 2.75)] x (12 in./ft.)3 = 3.26 ft3
Volumespan = N[A x L] = 4 x [13.88 x 98.75] x (12 in./ft.)3 = 3.17 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 3.26 = 125.8 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 3.17 = 122.4 lbs
Distributed Self Weight (ws) = = 14.87 plf
613.33 plf
78.33 plf
ws = 14.87 plf
8.23 ft.
8.46 ft.
2987.98 lbs
2987.98 lbs
10/11/2022 3
fb = = 838.8 psi
 fb = 838.8 psi < Fbx' = 920.0 psi  (CSI = 0.91)   ➜  OK
10/11/2022 4
fv* = = 63.85 psi
 fv* = 63.85 psi < Fvx' = 195.21 psi  (CSI = 0.33)   ➜  OK
fv = = 78.57 psi
 fv = 78.57 psi < Fvx' = 195.21 psi  (CSI = 0.40)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
10/11/2022 5
ΔLL = = 0.13 in.
(L/d)LL = 98.75 / 0.13 = 778
 ΔLL = 0.13 in = L/778 < L/480   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 98.75 / 0.15 = 675
 ΔTL = 0.15 in = L/675 < L/360   ➜  OK
fc⊥ = = 181.1 psi
 fc⊥ = 181.1 psi < Fc⊥x' = 378.55 psi  (CSI = 0.48)   ➜  OK
10/11/2022 6
