Beam Design - HOT TUB BEAM
Design Span (L): 9.10 ft.
Clear Span: 8.87 ft.
Total Span: 9.33 ft.
Bearing (lb): 2.75 in.
Quantity (N): 4
Live Load: 613.33 plf
Dead Load: 15 plf
Selfweight: 135.4 lbs
Dist. Selfweight: 14.87 plf
Total Weight: 138.8 lbs
Defl. Limits: 480|360
Beam Design DALE HANSEN 850 EDMONDSON RD, MONROE, GA 2022A662
10/11/2022 1
10/11/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 4 x [13.88 x (109.25 + 2.75)] x (12 in./ft.)3 = 3.60 ft3
Volumespan = N[A x L] = 4 x [13.88 x 109.25] x (12 in./ft.)3 = 3.51 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 3.60 = 138.8 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 3.51 = 135.4 lbs
Distributed Self Weight (ws) = = 14.87 plf
613.33 plf
15 plf
ws = 14.87 plf
9.10 ft.
8.87 ft.
9.33 ft.
3001.55 lbs
3001.55 lbs
10/11/2022 3
fb = = 934.6 psi
 fb = 934.6 psi > Fbx' = 920.0 psi  (CSI = 1.02)   ➜  NG
10/11/2022 4
fv* = = 65.73 psi
 fv* = 65.73 psi < Fvx' = 195.21 psi  (CSI = 0.34)   ➜  OK
fv = = 79.13 psi
 fv = 79.13 psi < Fvx' = 195.21 psi  (CSI = 0.41)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
10/11/2022 5
ΔLL = = 0.19 in.
(L/d)LL = 109.25 / 0.19 = 575
 ΔLL = 0.19 in = L/575 < L/480   ➜  OK
ΔTL = = 0.20 in.
(L/d)TL = 109.25 / 0.20 = 548
 ΔTL = 0.20 in = L/548 < L/360   ➜  OK
fc⊥ = = 181.9 psi
 fc⊥ = 181.9 psi < Fc⊥x' = 378.55 psi  (CSI = 0.48)   ➜  OK
10/11/2022 6
