Design Span (L): 17.42 ft.
Clear Span: 17.17 ft.
Total Span: 17.67 ft.
Live Load: 24.3 plf
Dead Load: 21.4 plf
Selfweight: 57.4 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 58.2 lbs
Beam Design 2022A66
2/8/2022 1
Beam Design 2022A66
2/8/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (209.04 + 3)] x (12 in./ft.)3 = 1.70 ft3
Volumespan = N[A x L] = 1 x [13.88 x 209.04] x (12 in./ft.)3 = 1.68 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.70 = 58.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.68 = 57.4 lbs
24.3 plf
21.4 plf
ws = 3.30 plf
17.42 ft.
17.17 ft.
17.67 ft.
432.88 lbs
432.88 lbs
Beam Design 2022A66
2/8/2022 3
fb = = 1042.6 psi
 fb = 1042.6 psi < Fbx' = 1138.5 psi  (CSI = 0.92)   ➜  OK
Beam Design 2022A66
2/8/2022 4
fv* = = 42.05 psi
 fv* = 42.05 psi < Fvx' = 207.00 psi  (CSI = 0.20)   ➜  OK
fv = = 46.14 psi
 fv = 46.14 psi < Fvx' = 207.00 psi  (CSI = 0.22)   ➜  OK
Beam Design 2022A66
2/8/2022 5
ΔLL = = 0.32 in.
(L/d)LL = 209.04 / 0.32 = 657
 ΔLL = 0.32 in = L/657 < L/360   ➜  OK
ΔTL = = 0.64 in.
(L/d)TL = 209.04 / 0.64 = 326
 ΔTL = 0.64 in = L/326 < L/240   ➜  OK
fc⊥ = = 96.2 psi
 fc⊥ = 96.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.15)   ➜  OK
Beam Design 2022A66
2/8/2022 6
