Beam Design - MedWand CES 2022
Grade: SP Standard
Size: 2 x 4
Design Span (L): 3.75 ft.
Clear Span: 3.50 ft.
Total Span: 4.00 ft.
Live Load: 0 plf
Dead Load: 95.6 plf
Selfweight: 10.2 lbs
Dist. Selfweight: 2.72 plf
Total Weight: 10.9 lbs
Load Duration: 1.25
Beam Design 5518
10/11/2022 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
SP Standard 475 275 175 565 1300 1200000 440000 0.55
Beam Design 5518
10/11/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [5.25 x (45.00 + 3)] x (12 in./ft.)3 = 0.29 ft3
Volumespan = N[A x L] = 2 x [5.25 x 45.00] x (12 in./ft.)3 = 0.27 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.29 = 10.9 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.27 = 10.2 lbs
Distributed Self Weight (ws) = = 2.72 plf
0 plf
95.6 plf
ws = 2.72 plf
3.75 ft.
3.50 ft.
4.00 ft.
196.64 lbs
196.64 lbs
Beam Design 5518
10/11/2022 3
Fbx' = (475)(0.9)(1)(1)(1)(1)(1)(1) = 427.5 psi
fb = = 338.6 psi
 fb = 338.6 psi < Fbx' = 427.5 psi  (CSI = 0.79)   ➜  OK
Beam Design 5518
10/11/2022 4
Fvx' = (175)(0.9)(1)(1)(1) = 157.50 psi
fv* = = 22.24 psi
 fv* = 22.24 psi < Fvx' = 157.50 psi  (CSI = 0.14)   ➜  OK
fv = = 26.34 psi
 fv = 26.34 psi < Fvx' = 157.50 psi  (CSI = 0.17)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1200000(1)(1)(1) = 1200000 psi
Beam Design 5518
10/11/2022 5
ΔLL = = 0.00 in.
(L/d)LL = 45.00 / 0.00 = ∞
ΔTL = = 0.03 in.
(L/d)TL = 45.00 / 0.03 = 1323
 ΔTL = 0.03 in = L/1323 < L/240   ➜  OK
fc⊥ = = 21.8 psi
 fc⊥ = 21.8 psi < Fc⊥x' = 565.00 psi  (CSI = 0.04)   ➜  OK
Beam Design 5518
10/11/2022 6
