Beam Design - casa
Species: Western Cedars
Grade: WC SS
Size: 4 x 12
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Live Load: 165 plf
Dead Load: 110 plf
Selfweight: 223.8 lbs
Dist. Selfweight: 13.77 plf
Total Weight: 227.2 lbs
Orientation: Horizontal
CF Size Factor 1.1 1 - 1 - -
Beam Design Alfonso Perez 1
10/10/2022 1
WC SS 1000 600 155 425 1000 1100000 400000 0.36
G = 0.36
10/10/2022 2
= 25.18 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [39.38 x (195.00 + 3)] x (12 in./ft.)3 = 9.02 ft3
Volumespan = N[A x L] = 2 x [39.38 x 195.00] x (12 in./ft.)3 = 8.89 ft3
Total Weight (WT) = ρw x Volumetotal = 25.18 x 9.02 = 227.2 lbs
Self Weight (WS) = ρw x Volumespan = 25.18 x 8.89 = 223.8 lbs
Distributed Self Weight (ws) = = 13.77 plf
165 plf
110 plf
ws = 13.77 plf
16.25 ft.
16.50 ft.
2382.36 lbs
2382.36 lbs
10/10/2022 3
Fby' = (1000)(1.00)(1)(1)(1)(1.1)(1.1)(1)(1) = 1210.0 psi
fb = = 2489.9 psi
 fb = 2489.9 psi > Fby' = 1210.0 psi  (CSI = 2.06)   ➜  NG
10/10/2022 4
Fvy' = (155)(1.00)(1)(1)(1) = 155.00 psi
fv* = = 43.09 psi
 fv* = 43.09 psi < Fvy' = 155.00 psi  (CSI = 0.28)   ➜  OK
fv = = 44.69 psi
 fv = 44.69 psi < Fvy' = 155.00 psi  (CSI = 0.29)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1100000(1)(1)(1) = 1100000 psi
10/10/2022 5
ΔLL = = 2.93 in.
(L/d)LL = 195.00 / 2.93 = 67
 ΔLL = 2.93 in = L/67 > L/360   ➜  NG
ΔTL = = 5.12 in.
(L/d)TL = 195.00 / 5.12 = 38
 ΔTL = 5.12 in = L/38 > L/240   ➜  NG
Fc⊥y' = (425)(1)(1)(1) = 425.00 psi
Ab = d x lb = 11.25 x 3 = 33.75 in2
fc⊥ = = 35.3 psi
 fc⊥ = 35.3 psi < Fc⊥y' = 425.00 psi  (CSI = 0.08)   ➜  OK
10/10/2022 6
